Deployed alerts are getting these types of alerts from today. I am using MYSQL and running simple queries. Those alerts were working fine before today.
Need urgent help.
Error: request handler failed to convert dataframe “results” to plugins.DataTimeSeriesSlice: input frame is not recognized as a time series
I’m getting the same error on Grafana 8.0.3 and 8.0.6, both on time series and bar graph alerts
I am hitting the same result. I am using grafana v8.0.6. I am using Postgresql. Please fix it asap.
Error message
request handler failed to convert dataframe "results" to plugins.DataTimeSeriesSlice: input frame is not recognized as a time series
I am not sure if it is related, but strangely data link variable is resolved to “results” instead of actual value. Here is the link to other issue that I have hit : Grafana 8 breaks Data Link variable to be "results"
you should report this in the repo:
