Grafana Version : v8.0.6
I was using Graph Visualization. When I upgraded to grafana 8, it no longer passes the column variable correctly. Following is my data link:
/d/mongodb_dynamic/mongodb-detail?var-column=${__series.name}&from=${__from}&to=${__to}
Expected URL picks up the series name:
http://.../d/mongodb_dynamic/mongodb-detail?var-column=limit
Actual URL (Broken) The value is changed to “results” for some reason :
http://.../d/mongodb_dynamic/mongodb-detail?var-column=results
