Upgraded from 7.5.4 to 8.0.3, Alerts throwing: input frame is not recognized as a time series grafana
    8.0.3, RHEL 8
    Queries that were working for alerts in 7.5.4 are now throwing an error.
    Add alerts to a graph. I’ve tried the old and new version. Graph points to an InfluxDB datasource using Flux to pull data
  • What happened?
    The alerts we had before should work like they used to or be easily converted.
    Worked before:
    from(bucket: “-----------”)
    |> range(start: -15m)
    |> filter(fn: (r) =>
    r.host == “-----------”
    |> group()
    |> count()
I tried changing it to this, but same result.
|> range(start: -15m)
|> filter(fn: (r) =>
|> group()
|> count()
|> map(fn: (r) => ({
r with
_time: now()
request handler failed to convert dataframe “” to plugins.DataTimeSeriesSlice: input frame is not recognized as a time series
Ok. So it appears that adding that map with did fix it. Not sure what I was looking at that made me think it was still busted.
I’m continuing to experiment.
