Grafana 11 on Rocky Linux 9.4 -
Ingest some data from Zabbix 7 server -
Zabbix Plugin
What happened?
Lack of a tags drop down for Query Type “text”. I only see the now deprecated “Application” -
An option for tags so I can enter component: os -
Sure
No
No, I can’t find much specific to handling the new tags feature in Zabbix.
If I select Query Type Metrics, then Application is replaced by Tags. This doesn’t appear to be available under Query Type text.
On the original zabbix and grafana server I had a nice dashboard that gave a lot of useful linux server data. This particular panel just gave the OS version and the panel next to it will display the kernel version.
Here’s the original for example:
And the new one if I have Metrics selected which doesn’t give me the option to actually extract the correct item:
and here’s with Text selected and you can see it only has Application:
Not sure what the workaround is. Is there a way to update the text query type to get the tags option? Since the old one is Text I’m assuming that’s what will work on the new one.
Here’s my item in Zabbix as well. With Tags “component: os”
Thanks.
