- I’m using Grafana 11.6 and the Zabbix Grafana plugin version 6.0.0 on a Linux vm
- i’m creating a dashboard similar to the one from Zabbix for the vms.
What happened?
- Some info do not show any data, like the cluster name, hypervisor name of the vm
- To see these info
- No errors. But in the query, the item does not show up.
You are probably trying to present a text item as a metric, change your query type to text.
Hello.
Thank you, that’s why I did besides modifiying the Relative time to 24h.
