I’m absolutely newbie in zabbix and grafana using. I did install zabbix plugin (4.5.2) to grafana and enable it. Zabbix plugin was set up and connected (everything seems ok and green).
But, when I try to add new visualization (gauge) and sett up it, it show only “no data”.
I can see:
Data source: my zabbix
Query type: metrics
Group: my groups
Host: my host
Application: temperature probe/nothing
Item: temperature probe/nothing
I would like sett up “gauge” for monitoring temperature in DC room (I have HWg-STE device, in Zabbix I see actual temperature).
I did set up value mappings too, but still nothing, no data.
Can you please advice me, I’m at loss. What I’m doing bad?
Thank you.
try switch t o a table view instead of the gauge, and see if you are actually getting data back, you can use the query inspector to help see what is going on as well
