As of last night, all widgets on my grafana dashboard are failing and it shows the error message:
SeatSpy plugin failed
Error: Could not load plugin: Error: 404 , loading Grafana (SystemJS Error#7 systemjs/docs/errors.md at main · systemjs/systemjs · GitHub)
No changes were made to the dashboard or the SQL database that the data comes from. When trying to create a new dashboard and a new Microsoft SQL Server data source it shows this same error message.
- Using Grafana Cloud
- get a dashboard that has worked for months to work again
asking this question
What happened?
- no changes to dashboard or SQL Server database, the grafana dashboard started reporting this error
- SeatSpy Plugin Failed
- Error: Could not load plugin: Error: 404 , loading Grafana (SystemJS Error#7 systemjs/docs/errors.md at main · systemjs/systemjs · GitHub)
