when I add the transformation “Add field from calculation” to a datasource it displays a respective graph on the time series on top of the original data. I don’t see the point in that and I’m not sure if I’am using that correctly. I actually just want to have the mean, min and max values shown over the chosen time interval. Any ideas how to handle that correctly?
I’m using a Postgres DB. The time series uses a table in the same dashboard as datasource.
