Grafana v10.1.5 (849c612fcb)
I would like to graph the maximum value as constant/threshold of a “complex” (joining and aggregation) time serie.
I’m graphing “complex” (joining and aggregating) time series about CPU usage. I’m computing the max value about one of them and would like to graph this computed “constant”
I tried to compute the maximum value using “Reduce” transformation:
- Mode:
Reduce field - Calculations:
Max - Include time:
false
What happened?
Output data didn’t contains time field so can’t be graphed (resumed):
refId: "my-data",
meta: {
type:"timeseries-multi"
preferredVisualisationType:"graph"
fields: [
labels: {},
values: [
0.058099523086942904
Draw the unique value as a constant (or find out some way to graph it).
(example from https://play.grafana.org)
"id": 21,
"type": "timeseries",
"title": "Cluster CPU usage (by Namespace)",
"gridPos": {
"x": 12,
"y": 7,
"h": 16,
"w": 12
"fieldConfig": {
"defaults": {
"custom": {
"drawStyle": "line",
"lineInterpolation": "linear",
"barAlignment": 0,
"barWidthFactor": 0.6,
"lineWidth": 1,
"fillOpacity": 10,
"gradientMode": "none",
"spanNulls": false,
"insertNulls": false,
"showPoints": "never",
"pointSize": 5,
"stacking": {
"mode": "none",
"group": "A"
"axisPlacement": "auto",
"axisLabel": "",
"axisColorMode": "text",
"axisBorderShow": false,
"scaleDistribution": {
"type": "linear"
"axisCenteredZero": false,
"hideFrom": {
"tooltip": false,
"viz": false,
"legend": false
"thresholdsStyle": {
"mode": "off"
"color": {
"mode": "palette-classic"
"mappings": [],
"thresholds": {
"mode": "absolute",
"steps": [
"color": "green",
"value": null
"color": "red",
"value": 80
"overrides": []
"transformations": [
"id": "reduce",
"options": {
"reducers": [
"max"
"mode": "reduceFields",
"includeTimeField": false
"filter": {
"id": "byRefId",
"options": "/^(?:B)$/"
"pluginVersion": "11.5.0-81311",
"targets": [
"datasource": {
"uid": "${datasource}"
"exemplar": true,
"expr": "sum(node_namespace_pod_container:container_cpu_usage_seconds_total:sum_irate{cluster=\"$cluster\"}) by (namespace)",
"interval": "",
"legendFormat": "{{namespace}}",
"refId": "A"
"datasource": {
"exemplar": true,
"interval": "",
"refId": "B",
"hide": false
"datasource": {
"options": {
"tooltip": {
"mode": "single",
"sort": "none",
"hideZeros": false
"legend": {
"showLegend": true,
"displayMode": "list",
"placement": "bottom",
"calcs": []
N/A
N/A
