I am using Grafana on Cloud.
I’m trying to get the average graph from multiple plots.
I tried to use transform feature via add “Add field via calculation”
Problem is the transformation are dependant and I can not create seperated independant transformation for different calculation.
Is there any alternative solution?
Could it be done with override or other features?
Thanks
