Transform Data displayed as a graph in the same panel
Hi ,
I am using Grafana version 11.1.4
I have 2 sql queries of time series data displayed in a panel which are displayed in the panel.
Also, I need to display the transformed data as a graph in the same panel.
The transformation data is the difference between the queries A and B.
Is it possible to do that?
Could someone advise?
Thanks.
check out the add field from calculation transformations:
https://play.grafana.org/d/Ose-IbEnz/transformation-calc-test?editPanel=2&tab=transformations
Thanks for the reply. But if I am not wrong, it seems to work only for stats. I need to use it for timeseries data and then plot it as a graph.
it works for time series as well
