About graphing transformations
Hello all,
I am thinking of creating gauge visualization for the two calculations under “Transform”. I am stuck at it because Grafana is somehow showing the graph for the two queries and not the two transformations.
I would really appreciate some help on this.
-Thanks
Can you share a screenshot of your data in the table panel at this point, @bieintern ?
You are adding a new field from each query but you probably need to hide/reorganize things a bit…It looks like you wrote two queries? Can you share those? That would also likely mean that you will need to join those tables before these calculations work the way you want them to…
