What Grafana version and what operating system are you using? - 10.3.1
What are you trying to achieve? A time series plot showing the results from only the two transforms and not the data queries.
How are you trying to achieve it? Create two transforms. Tried “Replace All Fields” option.
What happened? The time series graph will only show the output from one of the transforms when “Replace All Fields” selected.
What did you expect to happen? Two plots, one from each transform.
Can you copy/paste the configuration(s) that you are having problems with? Not necessary.
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. None
