Transform format time on time series
every time I try to transform the time format on a time series chart, it doesn’t work.
On a bar chart I have no problem.
But on a time series, here’s the problem I’m having:
Sometimes, when there are two queries, you have to join the two. That’s why there’s a “Join by field” transformation. With or without I have no change.
Here’s the result with a bart chart
Version : v10.4.1 Grafana Enterprise (no licence)
Database : InfluxDB v.2.7.4
Thanks for the help
Please share a screen capture of the query tab
Thanks for your answer
Here’s a screenshot of my current graph.
The 3 queries concern the same field, but they don’t do the same thing. The first is for the week, the second is for the weekend and the last is for a variable threshold based on the average of the values read.
What’s more, if I try with a new panel and insert a simpler query :
And now, i add the transformation :
whereas with a bar chart :
No problem
probably because it’s an alpha version of the transformation
Any solutions for this yet? I am having the same problem.
