Bar width in time series is way to slim (SensorThings API)
Hello dear people,
so I am very new to creating Grafana dashboards and I am currently out of ideas with my problem here. I realize that similar issues have been brought up in the discussions and I am trying to get a hang of everything, but I have not found a thread discussing my specific issue, at least not with the data source I am using.
I am using Grafana Cloud and my data source is SensorThings API with the STA plugin as I am fetching data from an IoT database. My query returns a “Time” field (YYYY-MM-DDThh:mm:ssZ) and a “Result” field with an integer. It looks as follows:
/Datastreams(<iot id>)/Observations?$orderby=phenomenonTime asc&$filter=phenomenonTime ge 2010-01-01T00:00:00Z and phenomenonTime le 2024-06-30T23:59:59Z
The “phenomenonTime”-field is then represented as the “Time” variable as can be seen from thies screenshot of the table-view:
I realize that the time format kind of correlates with the line thickness in some way I don’t understand fully. What I think I know is that I somehow have to transform the time field to be “YYYY-MM-DD” instead of “YYYY-MM-DD hh:mm:ss” so Grafana understands this is “daily” data and not data that is represented in a timestamp.
The SensorThings API doesn’t support “$groupby” which would be an easy way to solve this and you instead have to use “$apply=aggregate()” which doesn’t grant a result either. Here’s the query I’ve tried:
/Datastreams(4502)/Observations?$apply=aggregate(sum(Result) as TotalUsage) by floor(phenomenonTime/1000)/86400&$orderby=phenomenonTime asc&$filter=phenomenonTime ge 2010-01-01T00:00:00Z and phenomenonTime le 2024-06-30T23:59:59Z
The “Group By” transformation option doesn’t do anything at all:
Also I have tried adjusting the query options, but I don’t know if I did it correctly:
I have tried verious other transformation options which do not correspond with what I am trying to achieve.
Am I on the right track at all? I really don’t know what else to try or to do…
Here’s how the current chart looks with the “Bar width factor” “Line width” and “Fill opacity” maxed out:
JSON dump of the query inspector:
  "id": 1,
  "type": "timeseries",
  "title": "Panel Title",
  "gridPos": {
    "x": 0,
    "y": 0,
    "h": 8,
    "w": 12
  "fieldConfig": {
    "defaults": {
      "custom": {
        "drawStyle": "bars",
        "lineInterpolation": "linear",
        "barAlignment": 0,
        "barWidthFactor": 1,
        "lineWidth": 10,
        "fillOpacity": 100,
        "gradientMode": "none",
        "spanNulls": false,
        "insertNulls": false,
        "showPoints": "auto",
        "pointSize": 5,
        "stacking": {
          "mode": "none",
          "group": "A"
        "axisPlacement": "auto",
        "axisLabel": "",
        "axisColorMode": "text",
        "axisBorderShow": false,
        "scaleDistribution": {
          "type": "linear"
        "axisCenteredZero": false,
        "hideFrom": {
          "tooltip": false,
          "viz": false,
          "legend": false
        "thresholdsStyle": {
          "mode": "off"
      "color": {
        "mode": "palette-classic"
      "mappings": [],
      "thresholds": {
        "mode": "absolute",
        "steps": [
            "value": null,
            "color": "green"
            "value": 80,
            "color": "red"
    "overrides": []
  "pluginVersion": "11.3.0-74868",
  "targets": [
      "datasource": {
        "type": "iosb-sensorthings-datasource",
        "uid": "cdvowokci0c8wd"
      "refId": "A",
      "cacheDurationSeconds": 300,
      "method": "GET",
      "queryParams": "",
      "urlPath": "/Datastreams(4502)/Observations?$orderby=phenomenonTime asc&$filter=phenomenonTime ge 2010-01-01T00:00:00Z and phenomenonTime le 2024-06-30T23:59:59Z",
      "fields": [
          "name": "Time",
          "jsonPath": "$.value[*].phenomenonTime",
          "language": "jsonpath"
          "name": "Result",
          "jsonPath": "$.value[*].result",
  "maxDataPoints": 31,
  "datasource": {
    "uid": "cdvowokci0c8wd",
  "interval": "1d",
  "options": {
    "tooltip": {
      "mode": "single",
      "sort": "none"
    "legend": {
      "showLegend": true,
      "displayMode": "list",
      "placement": "bottom",
      "calcs": []
  "timeFrom": "1d"
Sorry for being a noob and thank you in advance for your time and effort! I am happy to supply additional information if needed!
@aneumann97
I think a better solution for you would be the “Bart Chart” panel instead of Time series (Bars)
Unf. Bar chart doesn’t work with this “YYYY-MM-DDThh:mm:ssZ” format
So you have to use “Transform(ation)” → “Convert field type” to convert values Time column to “YYYY-MM-DD” (String) only like below and you should be good to go :wink:
To get something like this…
