Hi all,
I have encountered this error message after I entered the id and password on the redirect fusionAuth page.
The docker log is showing things like:
t=2022-11-23T05:55:20+0000 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=302 remote_addr=xxx time_ms=4 size=305 referer=http://grafana.staged-by-discourse.com/login
t=2022-11-23T05:55:32+0000 lvl=info msg="state check" logger=oauth queryState=xxx cookieState=xxx
t=2022-11-23T05:55:32+0000 lvl=eror msg=login.OAuthLogin(NewTransportWithCode) logger=context userId=0 orgId=0 uname= error="Post \"http://localhost:9011/oauth2/token\": dial tcp 127.0.0.1:9011: connect: connection refused"
t=2022-11-23T05:55:32+0000 lvl=eror msg="Request Completed" logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=500 remote_addr=xxx time_ms=9 size=1365 referer=http://localhost:9011/
and the network gives back 500 internal server error
More info:
Here is the Grafana setting
- GF_SERVER_DOMAIN=localhost
- GF_SERVER_HTTP_PORT=3000
- GF_SERVER_PROTOCOL=http
- GF_SECURITY_ADMIN_USER=admin
- GF_SECURITY_ADMIN_PASSWORD=password
- GF_USERS_ALLOW_SIGN_UP=false
- GF_AUTH_GENERIC_OAUTH_ENABLED=true
- GF_AUTH_GENERIC_OAUTH_CLIENT_ID=xxx
- GF_AUTH_GENERIC_OAUTH_CLIENT_SECRET=xxx
- GF_AUTH_GENERIC_OAUTH_AUTH_URL=http://localhost:9011/oauth2/authorize
- GF_AUTH_GENERIC_OAUTH_TOKEN_URL=http://localhost:9011/oauth2/token
- GF_AUTH_GENERIC_OAUTH_API_URL=http://localhost:9011/oauth2/userinfo
- GF_AUTH_GENERIC_OAUTH_USE_PKCE=true
The direct login on Grafana without OAuth is working properly.
I am using Docker compose to build up Grafana and other services, they are connected with bridge network and communicating properly.
The OAuth login was working fine before, but suddenly no longer be able to redirect back to Grafana dashboard, not sure if I did anything wrong ![]()
Can anyone help with this problem?
