RHEL8.6 Grafana 9.6 -
Find more post for solve this problem but not match. -
Tacking network it allow and can access. -
What happened?
Can not use OAuthLogin ? error
logger=context userId=0 orgId=0 uname= t=2023-01-24T14:52:51.28735047+07:00 level=error msg=login.OAuthLogin(NewTransportWithCode) error="Post \"https://accounts.google.com/o/oauth2/token\": dial tcp 172.217.25.205:443: connect: connection timed out"
logger=context userId=0 orgId=0 uname= t=2023-01-24T14:52:51.287624215+07:00 level=error msg="Request Completed" method=GET path=/login/google status=500 remote_addr=1.20.61.241 time_ms=262904 duration=4m22.904587187s size=1365 referer=https://accounts.google.co.th/ handler=/login/:name_badge:
I want to use OAuth 2 login to Grafana.
- Can you copy/paste the configuration(s) that you are having problems with?
[auth.google]
enabled = true
allow_sign_up = true
client_id =
client_secret =
scopes = https://www.googleapis.com/auth/userinfo.profile https://www.googleapis.com/auth/userinfo.email
auth_url = https://accounts.google.com/o/oauth2/auth
token_url = https://accounts.google.com/o/oauth2/token
api_url = https://www.googleapis.com/oauth2/v1/userinfo
allowed_domains = gmail.com
hosted_domain = true
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
- Request URL:
[type or paste code here](https://XXX.co.th:3443/login/google?state=XXXXX=email+profile+https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fuserinfo.profile+https%3A%2F%2Fwww.googleapis.com%2Fauth%2Fuserinfo.email+openid&authuser=0&prompt=consent)
- Request Method:
GET
- Status Code:
500 Internal Server Error
- Remote Address:
123.189.210.11:34430
- Referrer Policy:
strict-origin-when-cross-origin
- Did you follow any online instructions? If so, what is the URL?
Yes , i trie to do it ,But it not work.
