Dear all,
I’m configuring an application using a docker-compose where there are grafana and also keycloak as identity provider.
When I go to community.grafana.com grafana redirect me to the keycloak login page, but once I authenticate keycloak redirect me to grafana which shows an error message like:
login.OAuthLogin(NewTransportWithCode)
The grafana log file says:
t=2020-07-22T13:54:16+0000 lvl=eror msg=login.OAuthLogin(NewTransportWithCode) logger=context userId=0 orgId=0 uname= error=“Post "https://localhost:10443/auth/realms/simile/protocol/openid-connect/token\”: dial tcp 127.0.0.1:10443: connect: connection refused"
t=2020-07-22T13:54:16+0000 lvl=eror msg=“Request Completed” logger=context userId=0 orgId=0 uname= method=GET path=/login/generic_oauth status=500 remote_addr=172.24.0.1 time_ms=1 size=1744 referer=
Hereinafter my env configuration:
GF_AUTH_GENERIC_OAUTH_NAME=OAuth
GF_AUTH_GENERIC_OAUTH_ENABLED=true
GF_AUTH_GENERIC_OAUTH_ALLOW_SIGN_UP=true
GF_AUTH_GENERIC_OAUTH_CLIENT_ID=simile-grafana
GF_AUTH_GENERIC_OAUTH_CLIENT_SECRET=66eb44de-5d54-4fe8-ac49-9cc6832cb4e1
GF_AUTH_GENERIC_OAUTH_SCOPES=openid profile
GF_AUTH_GENERIC_OAUTH_EMAIL_ATTRIBUTE_NAME=email
GF_AUTH_GENERIC_OAUTH_AUTH_URL=https://localhost:10443/auth/realms/simile/protocol/openid-connect/auth
GF_AUTH_GENERIC_OAUTH_TOKEN_URL=https://localhost:10443/auth/realms/simile/protocol/openid-connect/token
GF_AUTH_GENERIC_OAUTH_API_URL=https://localhost:10443/auth/realms/simile/protocol/openid-connect/userinfo
GF_AUTH_GENERIC_OAUTH_TLS_SKIP_VERIFY_INSECURE=true
Why is this happening?
Thank you for your help
Daniele
