Grafana keycloak authentication Error
Regarding grafana integration with Keycloak OAuth2. Currently facing an issue where after the login page of keylock and the credential are put it login redirects to grafana website with port 3000. This is the error
This site can’t be reached grafana.xxx.xx.xx refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED.
But if the 3000 is removed from the link it opend the grafana page
grafana.xxx.xxx.xxx:3000/login/generic_oauth?state=xxxxxx
So when the 3000 is removed it loads the grafana page.
Have grafana install from helm chart below are the settings from the values.yaml
 grafana.ini:
    auth.generic_oauth:
      enabled: true
      tls_skip_verify_insecure: true
      allow_sign_up: true
      client_id: grafana-sso
      client_secret: xxxxxxxxxxxxx
      scopes: openid email profile offline_access roles web-origins
      email_attribute_path: email
      login_attribute_path: username
      name_attribute_path: full_name
      auth_url: 'xxx://ssoxxxx.xxx.xxx/auth/realms/xxx/protocol/openid-connect/auth'
      token_url: 'xxxx://ssoxxxx.xxx.xxx/auth/realms/xxx/protocol/openid-connect/token'
      api_url: 'xxx://ssoxxxx.xxx.xxx/realms/xxx/protocol/openid-connect/userinfo'
      role_attribute_path: contains(roles[*], 'admin') && 'Admin' || contains(roles[*], 'editor') && 'Editor' || 'Viewer'
    server:
      domain: grafanaxxx.xxx.xxx
Keycloak Settings:
* Root URL: xxx://grafana.xxx.xxx.xx/
* Valid Redirect URIs: "*" (have wildcard here because using the url/login/generic_oauth gave Invalid parameter: redirect_uri)
* Base URL: xxxx://grafana.xxx.xxx.xx/
* Admin URL: xxx://grafana.xxx.xxx.xx/
For the callback URL to be correct, it might be necessary to set the root_url option in the [server]section of the Grafana configuration file. For example, if you are serving Grafana behind a proxy.
Please use code format for better readability
Hi I did put the root_url but the same issue is there
    server:
      domain: grafana.xxx.xx.xxx
      root_url: https://grafana.xx.xxx/
How is it possible, when:
Thanks it worked, the pervious one was just still in the cache
