Grafana - keycloak openid connect integration
Version 9.1.5 (commit: df015a9301, branch: HEAD)
Ubuntu 18.04.6 LTS
Trying to use keycloak for SSO with grafana.
grafana.ini
[server]
protocol = http
domain = localhost
root_url = http    ://172.18.63.227:3000/
[auth.generic_oauth]
enabled = true
name = OIDC
;allow_sign_up = true
client_id = dra-grafana
client_secret = A5wrlAYIb7qc2TQejdgtyxAQPFIGfRdw
scopes = openid profile email
;empty_scopes = false
;email_attribute_name = email:primary
;email_attribute_path =
;login_attribute_path =
;name_attribute_path =
;id_token_attribute_name =
auth_url = http  ://   172.18.63.227:8080/realms/master/protocol/openid-connect/auth
token_url = http ://   172.18.63.227:8080/realms/master/protocol/openid-connect/token
api_url = http ://   172.18.63.227:8080/realms/master/protocol/openid-connect/userinfo
;teams_url =
;allowed_domains =
;team_ids =
;allowed_organizations =
;role_attribute_path =
;role_attribute_strict = false
;groups_attribute_path =
;team_ids_attribute_path =
;tls_skip_verify_insecure = false
;tls_client_cert =
;tls_client_key =
;tls_client_ca =
use_pkce = false
;auth_style =
  • What happened?
logger=context traceID=00000000000000000000000000000000 userId=0 orgId=0 uname= t=2022-11-16T05:39:38.099765531Z level=info msg="Request Completed" method=GET path=/login/generic_oauth status=302 remote_addr=10.107.148.13 time_ms=1 duration=1.148735ms size=322 referer=http://172.18.63.227:3000/login traceID=00000000000000000000000000000000 handler=/login/:name
logger=oauth t=2022-11-16T05:39:40.429163512Z level=info msg="state check" queryState=37317a2e60432e903fb058be6fbcc833f5f5dfd9ec3cc02be8782e5b8eaeb92f cookieState=37317a2e60432e903fb058be6fbcc833f5f5dfd9ec3cc02be8782e5b8eaeb92f
logger=oauth.generic_oauth t=2022-11-16T05:39:40.475729679Z level=error msg="Error getting email address" url=http
   ://172.18.63.227:8080/realms/master/protocol/openid-connect/userinfo/emails error="{\"error\":\"RESTEASY003210: Could not find resource for full path: http://172.18.63.227:8080/realms/master/protocol/openid-connect/userinfo/emails\"}"
Successful login page.
login.OAuthLogin(get info from generic_oauth)
Check this Connection to Keycloak broken, possibly due to a Grafana upgrade
thank you so much … I had the same issue as documented in the link pointed and was able to get grafana working with keycloak
