I’d like to generate a query that generates a table.
The value of column 1 needs to be a link to another dashboard which will be set up to use that value as a parameter in a query.
Currently, the data that is returned is like the following:
“[SITE] - Customer Name - Normal”
When the table is drawn out, the link looks like the following:
https://blahblah.com/dashboard/db/events-test?blah=[SITE]%20-%20Customer%20-%20Normal
When the value of the parameter is fed back into the next dashboard, I am not getting any results, because I think the actual value going into it is: “[SITE]%20-%20Customer%20-%20Normal”
Instead of: “[SITE] - Customer - Normal”
Am I assuming right? If so, how do I get around that?
I am on Grafana 6.2.0 and am using mysql and the table widget.
