Data link that takes variable values from another column
I have a query variable in my grafana dashboard (machine dashboard):
database with 1 value: DP_Database
table with 3 values: 711_Table, 732_Table, 589_Table
now I want a data link to link to 1 single dashboard and auto fill in the tables in the table variable in the query per panel. This link is going to be attached to a table in another dashboard (machine picker dashboard)
I am also sending database and table as datapoints and querying them into the table on the machine picker dashboard
I want to be able to click a value under “Machine Name” and let the data link take the database and table from the same row, but a different column:
i hope my drawing makes sence :slight_smile:
Does somebody know what to fill into the data link?
this works, but I can’t hide the database and table columns from the table panel (with “organize fields by name” transformation).
any idea on how I can hide them?
edit: figured it out with an override:
