I have tried populating below as best as possible.
Thanks,
Vaughn
v11.2.0 -
Create a dashboard link that is hidden from users that don’t have permission to the intended dashboard -
Adding a standard dashboard link via the new link area in a dashboard -
What happened?
All used can click the link, but it just shows that the dashboard is not available -
When a limited user opens a dashboard, links to other dashboards not available to the current user must also be hidden -
