Have installed latest version of Grafana, created multiple users, added them to the same Organization with Viewer permission. The users are able to login but cannot view any dashboard that I create as the Admin of the Org.
What am i missing?
Hello!
I just want to check if you have solved the problem?
If not, have you checked the dashboard’s permissions to make sure that viewers are able to view the dashboard? Also, have you made sure that the users are part of the same organisation where you have created the dashboard, and that they are not accidentally part of another org?
