I have created an organisation, a user, and a dashboard.
But there’s no way I can login as this user and see the dashboard.
I have tried everything I can think of. It seems to be a bug or it works very unlogical.
Help!!
Thnx,
Mike
Help!!
Thnx,
Mike
update: if I create a dashboard and user in the default organisation all is fine.
yes, but that migt be a bug. Is this a bug too ?
If you read the whole topic I linked to you should see that it’s probably the same problem as you reported. There’s an issue open.
Marcus
