Line chart does not display data correctly
    9.2.5, Windows 10
    I am trying to show data on line chart.
  • What happened?
    I fetched the data with MSSQL datasource.
    The data appears correctly in the table view. But when I switch to chart view, the data changes. Showing data from about 3 hours ago.
The query i wrote;
query
Data returned from query;
The data shown in the chart.
The time at the point I showed with my mouse is 13:06:32, but there is another recording data at this time.
    I was expecting to visualize exactly the data appearing in the table view.
If your datetime field UTC? If not use some mssql function to convert your datetime field to UTC
I don’t know exactly what the UTC format is, but I keep the time as “YYYY-MM-DD hh:mm:ss:xxx” in the database.
Utc is a timezone not a format.
What do you see when you do
select getdate()
in ssms
when i run select getdate() from DataLogTest, it gives me “2022-11-22 17:44:25:803”
Thank you very much, that solved my problem. I guess I’m using it in a production environment since there’s no daylight savings time in the area I live in.
