Limiting the zoom level range for zooming in and out in Geomap
I would like to limit the zoom level range for zooming in and out in Geomap.
I couldn’t find any options to restrict the zoom range in the editor screen.
How can I set these limits?
I want to restrict the zoom range with a minimum of 14 and a maximum of 18.
looks like there is no min but only Max?
Thank you for your message.
I have set the View mode to Coordinates because I want to specify the latitude and longitude for the initial display.
I am planning to use Geomap in an offline environment, and there is a requirement to limit the display range since downloading all data locally would be too much work.
Would it be possible to achieve this by modifying the JSON model settings in the configuration?
What data are you referring to, I am not sure I understand
I apologize for the insufficient explanation.
By “data,” I am referring to the image files of maps from the Geospatial Information Authority of Japan.
