Some way to not change the size on Geomap when zooming?
Hi there guys!
Currently working on a Geomap panel and facing with an issue. I’m using images with extension .svg for some item representations and I’m wondering if there is any way to avoid the icon’s size changing when I zoom-in and zoom-out the map. Something like putting an additional layer which don’t change the size on zooming on map.
Thanks in advance!
