I am using the Geomap plugin to display a fixed area with some dots in a Grafana panel.
When I access the dashboard from a computer, scrolling down in the dashboard does not impact the area displayed in the Geomap panel, and this is a desired behaviour.
However when I access the dashboard from the phone and I use my thumb in the middle of the screen to scroll down, if my thumb is on the Geomap panel the page will not scroll down but instead the map would be dragged.
I wonder if there is a way to avoid this by for example freezing the map, without removing zooming in and out options, so that from the phone I can scroll down without de-centering the map.
Thanks for your opinions!
Alberto
