I’m using Log Analytics from Azure Monitor to load in data to Grafana and visualize it.
When I use Azure workbooks, everything is working correctly:
When I do the same query and visualization in Grafana, I get weird behavior:
The visualization in Grafana also changes sometimes to show only a few values, or nothing at all. Changing the extend pipe to modify the same variable instead also changes the visualization, which is not the case in Azure Workbooks.
When I inspect the data in table format, it all looks correct.
Does someone have an idea of what I’m doing wrong here? I can add more pictures but I’m only allowed to insert 2 as a new user.
Thanks a lot!
