Version 9 -
Creating Dashboards for Azure Monitoring using Azure Log Analytics and Application Insights for API Managements services. -
Using Data Source Azure Log Analytics and Application Insights for API Managements services. -
What happened?
I am able to plot Render Timecharts using KQL in Log Analytics / Application Insights. But same is not plotting in Grafana using time series. -
Grafana using time series should be plotting graphs as Azure. -
// Count of failed and successful requests over time
requests
| extend success=tobool(success)
| where timestamp > datetime(“2022-07-14T17:38:00.000Z”) and timestamp < datetime(“2022-07-14T18:38:00.000Z”)
| where cloud_RoleName == ‘apim’
| where client_Type == “PC”
| summarize
succeeded=sumif(itemCount, success == true),
failed=sumif(itemCount, success == false)
by bin(timestamp, 1m) -
NO -
Nothing so far
