having a json config issue where the imported dashboard from another config doesn’t work when importing it.
Welcome @jun13 to the Grafana forum.
I’m afraid your question is not very specific. Did you export the JSON of one dashboard and try to import this into another (for example, from one Grafana installation to a new one)? Can you paste the JSON here for the dashboard which you are trying to import? Are any error messages being displayed?
What i did was copy the json model config and paste it into the other json model config page. When I click “Save changes” it says theres an issue with the uid and I change the uid to what it was in the original json content and after clicking “Save changes” it then says, “Dashboard cannot be changed to a folder”.
