hi all im trying to import a dashboard to grafana and i encounter some errors
if i change the name and iud still get the same error
what am i doing wrong?
thanks
Miguel
Hi Miguel! It doesn’t look like you’re doing anything wrong there, usually when you select the “change UID” button and rename the dashboard you’re importing, the duplicate naming message should disappear. If you’re still experiencing this issue I recommend open a ticket so the Support team can take a further look!
