Grafana 9.4.13 -
I would like to show time series with correct date. -
The query time series is on UTC. And the browser is in local time zone which is UTC + 8 -
What happened?
You can see in below image that the query result has been translated to UTC + 8. In the picture example it is 2024-02-23T16:00:00.000+08. Then the time range is also set to browser local time which is also UTC+8. But the data is plotted at 08.00 hour. Its treating the time series time interval as UTC.
The data should be shifted to the correc time according to the browser time.
