Data outside time range Europe/Madrid (CEST, +0200)
Server running Europe/Madrid (CEST, +0200), Grafana Browser set Time Spain, CEST UTC+02:00
  • Grafana v11.2.2 Debian ARM64
  • Data in real time
  • Time series chart with mysql query
  • What happened?
  • Data outside time range, shows 2h extra over values of timestamp in ‘time’ column.
  • Ex. Timestamp 11:00, data in chart is at 13:00.
  • Real time chart display
Save your data into DB in the UTC timezone.
I just tried, but same results, local time 14:25 (UTC+2) but Grafana still showing 16:25, i really can’t understand why
Edit: The time column
Data in the DB: in UTC timezone
Grafana DB user: UTC timezone (e.g. session time zone - I guess this is your problem - it returns +2 and then Grafana UI will add it as well +2)
Grafana UI: “moves” received UTC data to browser/dashboard/panel timezone
For your simplicity: set everything on the server side to UTC.
how did you do that?
changing the timezone in mysql? by editing /etc/mysql/mariadb.conf.d/50-server.cnf
I don’t think that changes your data in the database though. Use this function instead
convert_tz(time_stamp,'US/Eastern','UTC')
of course using your time zone name instead of US/Eastern
I don’t know. Check your db doc.
Unfortunately this doesn’t work in my case, i believe it’s because my timestamp value has name ‘time’.
  1. What data type is your time column?
  2. you need to modify the Format to Time series
I finally managed to get it working based on your solution, modified TZ with numerical values for UTC (+00:00) and -2:00 for my timezone and worked.
But i must say this isn’t practical at all when having to add much data…seen this issue is been present since 2021 and yet can’t be fixed?¿
Having to either set server to UTC or use CONVERT_TZ doesn’t seem normal to me.
That’s not solution. It’s only a workaround. Are you going to edit all your queries when CEST will change to CET and vice versa? That will happen in a few days, so prepare for another problem. Strictly use UTC and let client only (e.g. Grafana) to handle local timezones.
there are tons of time zones on planet earth (not sure about other planets, never been there) instead of trying to account for every single type of time zone, a good tool would design things to use one common time zone: UTC.
That’s exactly my point, no one uses UTC only. As my (and everyone else) server and db handle automatically cet/cest, why can’t grafana simply read that data as indicated in configuration of time series → Axis ->Time zone and just display it correctly based on settings of the Browser time settings picker?
No, nobody shows it in UTC, but everyone saves it in UTC.
Why no Prometheus user has a problem with timezone? Because Prometheus always keep data in UTC timezone by design. Poor designated SQL DBs have this problem usually. You keep in your poor DB that we will meet at 2024-10-10 09:00:00, so you will send me invitation with time 2024-10-10 09:00:00. And I guarantee that we don’t meet, because we are in different timezone, so we have time “2024-10-10 09:00:00” at different time points.
Yes, you can use local timezone, but it will be more complicated (e.g. PostgreSQL has timestamptz, so also timezone is saved - I can save in local timezone, but then I can query easily in UTC), so for your simplicity use UTC.
Grafana has proper timezone handling, but save and query in yhe UTC timezone. Yes, complain that’s wrong, but then think how can you solve problem with Daylight saving time - are you aware that different countries may have different time when they change DST, you can expect that some countries may refuse to use DST in the future at all.
So saves and query data in the Grafana in the UTC (visualize it in whatever timezone you want then in the UI) or suffer in the timezone hell forever.
