Grafana 9.1.8, oficial Docker container image, Mac M1 -
Show time series panels in my time zone (UTC-3), getting data from one GraphQL API of mine. -
I have:
- Ensured the UTC timezone on the container using environment
TZ: "UTC"
bash-5.1$ date
Wed Oct 12 14:16:14 UTC 2022
- Ensured my API was returning timestamps in UTC
0:Object
sum:30149769
ts:"2022-10-12T14:04:00"
Ensured the main configuration time zone is UTC through the Admin UI.
Tested my dashboard with many different time zones, UTC, from the browser, UTC-3, etc
Ensured the values time selector is being used on the query
${__from.date.iso} => 2022-10-12T14:01:04.847Z
${__to.date.iso} => 2022-10-12T15:35:04.847Z
- What happened?
When my dashboard is in UTC-3:
I can see a table panel with the UTC timestamp. For instance, inspecting the data I have2022-10-12T14:21:00and the same thing on the panel.
When I change the panel to a time series one, I got the message “Data outside time range”, which is a correct message, because in UTC-3 the timestamp should be “2022-10-12T11:21:00” -
When I change my dashboard to UTC:
That same table panel shows data 6 hours ahead of my time, even inspecting the query I see the timestamps returned by the API are in UTC.
Same “Data outside time range” on the time series panel. -
When I change the timezone on the main configuration none of the behaviors above change.
In many other questions, and in the docs, it is said that Grafana should adjust the timestamp for my current time zone, which is not happening and I can’t figure out why. -
Not sure what configurations could be useful here, but I can if needed. -
No -
Many quantions on the forum but no success.
