Is it possible to disable manually created dashboard, only allowing provisioned dashboards?
    Grafana 11.5.1 on Kubernetes
    I’m trying to set up Grafana completely “as-code”, making the Grafana installation itself “ephemeral”.
    I’m using the Grafana-operator to manage datasources in Grafana, and using GrafanaDashbord resources to manage the dashboards.
  • What happened?
    The Dashboards and Datasources provision just fine, and when trying to edit a dashboard, Grafana correctly informs that the Dashboard is provisioned, and only allows me to copy the JSON and add it as code.
    But when I go to the dashboard page and create a new Dashboard, I am still allowed to create the dashboard, and save it.
    I want to configure Grafana in a way such that when I create a new Dashboard, I’m allowed to get to the editor and tinker around with the Dashboard, but once I save the dashboard for the first time, I would like Grafana to give me the JSON and tell me that I must use Dashboard provisioning to manage all dashboards.
    I don’t think there’s any relevant configuration to post.
    Nope
    Nope, I did however try to search for information about disabling manual creation of dashboards, but couldn’t seem to find anything
You can use RBAC Grafana Role-based access control (RBAC) | Grafana documentation and configure/create user roles, so they won’t be able to manage dashboards (or other entities, e.g. folders, alerts,…). Only your code automation will have role with full permissions.
Will the users still be able to build the dashboard in the UI and output the JSON?
No, because UI is built on user role/permissions - there is no point in showing the “Create” button in the UI for the user when create&save fails because of insufficient user permissions.
You can test it with https://play.grafana.org/ - you have “viewer” role by default, so no create/update/delete and UI also reacts on that. But there is viewers_can_edit=true, so users can “edit” (view&modify, but not save) = explore dashboards.
IMHO it is not very smart to have full read-only access for the users. I would give them “dev” folder, where users will have RW access for UI dashboard development (again that’s possible with RBAC).
Have a 2+ environments, users build, test in dev.qa, then automate deployment to production when dashboard is ready
