Using Grafana 9.x -
I have added few grafana dashboards using file provisioning. And I want to disable few of the dashboards from command line and not from UI. -
I moved the json files to a different folder and marked it as .disable. I restarted the grafana server. -
What happened?
The grafana dashboards still show on the UI. -
I expected it to be deleted since I moved it into the .disable file toa different folder. -
