Provisioning Dashboard's permissions
Docker Grafana 8.1.0 image.
I have a set of dashboards and datasources that I have been able to successfully provision as apart of my docker container. I am embedding these dashboards into a web application. I am permitting “anonymous” access to allow viewing of these dashboards. However, one of these dashboards we want to have only accessible to the “admin” grafana user. The main goal is to have the dashboards and their permissions be provisionable.
I have a json file for each dashboard and I have my datasources defined in a yaml file. Using docker-compose I map these into the appropriate places and build my container. After starting the container I am modifying the permissions through the GUI interface and am exporting the JSON model for the dashboard and updating my source controlled JSON files that I use in the provision process.
  • What happened?
The datasources and dashboards are there, however, the permissions are not stored in the JSON model, so it seems.
To export the dashboard model with the saved permissions.
No
No
No
Since the launch of Grafana 8 the teams have been working on a new dashboard schema that should greatly improve dashboard workflows.
In those videos they talk about how provision will be one of the last steps in this process
I am running into this same problem. Have you found a solution?
Maybe you could run a script to update through the API?
It would be so simple to just store permissions in the dashboard.json file though.
