I’m showing lighning events on a geomap, and it works pretty well, but when the events are very close to each other, and very nearly overlapping, I’d love for those datapoints to share a preferably larger icon. I couldn’t find a simple option for that, but would it be possible to acheive it by some other (more advanced) method?
To illustrate what I mean. Here on zoom level 13, the markers are fairly spread out, but there are some clusters that could preferably share an icon for improved readability:
I noticed that when I place my coursor on a cluster, Grafana is at least aware that there are more than one marker close-by and merge them in the tool-tip:
Thank you for the suggestion. Not sure I’ll be able to figure the Leaflet plugin out yet, but will definitively try.
I was considering using the heatmaps instead (I should have mentioned that in the OP), I think it looks cool. I just wish I could decide the temperature color range myself - I’d rather avoid the reds, or have the greens replaced by purple (Just a minor aesthetic preferrence, not a big deal).
Great you’ve managed to get some points on it so fast!
There s a misguiding issue with size units in mapgl. They’re in meters, not pixels. So to make it visible on small zoom levels you’d have to make points as big as 500 meters in size, for example.
The sum up question you have is maybe caused by the same issue - you probably have 9 points but on a distance? And you don’t see the 9th because it is not close enough to get into a cluster and too small to be seen separately. Just a suggestion
Hello! I encountered a similar problem. Unfortunately, I didn’t understand how the author solved the problem from this discussion, so I decided to contact the plugin author (you). Could you please tell me how clustering is implemented in the plugin to achieve something like what user yosiasz demonstrated?
hi, unfortunetely clustering feature isn’t available in mapgl v.2 community version. It exists on < v2 , but overall UX is different from up to date version
