I’m looking to customize data visualization on a map in Grafana (data source: InfluxDB) by uniquely coloring the latest data points based on their timestamp (e.g., the last one in red, the penultimate in green, etc.) using the Geomap panel. I haven’t found a direct way to do this with standard features or transformations.
Does anyone have suggestions or creative solutions to share? Any help is greatly appreciated!
I do not believe that is possible in geomap at this time. but you can check this approach out that zooms to a specific location but you can modify it to color dynamically
What would the map look like with your requirements if you can use a picture app to model it
