8.2.5 -
I am able to visualize on geomap the location data (lat, long) from a table (by time), but I am not able to color the last location with a different color.
See the image.
I also duplicated the query, set LIMIT = 1 and colorized the single event, but in this attempt I cannot visualize both query results at the same time. -
What happened?
I am able to show all the positions but cannot color the last event. -
I want the last position to be colored differently from others. -
SELECT last(“Latitude”), last(“Longitude”) FROM “state” WHERE (“entity_id” = ‘sm_n975f_posizione_geocodificata’) AND time >= now() - 3d and time <= now() GROUP BY time(5m) fill(none) -
No error. -
No tips related to this.
