Grafana 8.0.3, Ubuntu 20.04 LTS -
Show the last location on WorldMap plugin -
Latitute and Logintude are stored in InfluxDB. When I use the following query:
SELECT LAST(“latitude”), “longitude” FROM “Test” WHERE (“location” = ‘GPS’)
I do get the last value.
> SELECT LAST(“latitude”), “longitude” FROM “351561110228836” WHERE (“location” = ‘GPS’)
time last longitude
1624788070243314898 XXXXXXX YYYYYYYY
What happened?
But when I use the same query in the Grafana dashboard, I am getting error -
The Influx query that was working on command line show work in Grafana as well.
