Hi, how are you?
I can’t find a slider for my dashboard to change a value like the image attached
Thanks very much
Hi, how are you?
Thanks very much
welcome to the
forum, @lcaste73
I’m a bit confused. That image doesn’t look like the Grafana UI. Are you building your own plugin? what are we looking at?
Your example looks like it was taken from Node-RED dashboard. Grafana is a much different product from Node-RED dashboard in that Grafana is a product to visualize data (and usually time series data from a time series database). Node-RED dashboard allows not only charts & graphs, but also controls, timers, buttons, etc.
