version 7.2.0 - What are you trying to achieve?
Grafana dashboard for netapp metrics with backend influxdb - How are you trying to achieve it?
Reading data from influxdb - What happened?
Error => Panel plugin not found: timeseries - What did you expect to happen?
I have updated all plugins from the grafana-cli, but still error persists - Can you copy/paste the configuration(s) that you are having problems with?
Attached is the error dashboard - Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Attached is the error dashboard - Did you follow any online instructions? If so, what is the URL?
Timeseries plugin is built-in panel plugin and it is available in newer Grafana. You have old version 7.2.x - current version is 9.2.x. So upgrade your Grafana and you won’t have this problem.
