Panel plugin not found: timeseries
kinda new to Grafana so please help…
ive install * Grafana vSphere Overview Dashboard – 8159 plugin
and get this error msg “Panel plugin not found: timeseries”
how do i add/install timeseries
Thanks
  • What happened?
I have the same problem - I just downloaded a Dashboard. And I see the same message in red where all the panels should be…
To remove the error I do like this:
Press the “panel-name” and choose “edit” - then I choose a graph and
…apply
Then the error is gone. I think something is wrong with the dashboard I downloaded…but I dont know.
