latest Grafana version and Windows 10
I have created a table in the MySQL database. The table contains 2 columns(col1:contains Ids, col2: contains image link). I have created a variable for the Ids in the dashboard. Now based on the Id that has been selected in the dashboard the corresponding image stored in the dashboard should be displayed.
I tried using the table panel using the ‘cell display mode’ (I have selected ‘image’ option in this mode) which helped me display the image in a row, but it is not as I had expected.
What happened?
The image displayed in the row is quite small and I am not able to increase its size (as well as row height).
I got the above solution in the Grafana community and I thought that I might have an option of increasing the row height, but there isn’t any.
If anyone wants to share any other solution, you are most welcome
This is the image what I got.
You can do it with the old Grafana v6 table panel which supports HTML tags. I use it to display captured CCTV still images in real time on a dashboard. Like you, my MySQL database contains an image path which the Grafana instance needs to have read access to to enable it to display.
The newer Grafana v7 (and I think v8 is same) table panel removed the feature that made this possible (sanitize html). But you can still use the old v6 table panel with Grafana v7 (and I think v8). See my post here on the topic:
Hi Can u tell me how u made the dynamic panel work…How was the data stored in the database (the image) and also how did u write the query …I am new to this and I am trying to achieve the same thing like with a drop down should be able to select the image …It would be really helpful if u could show a sample of the query and how to store the image in the database
