– enterprise version 9.5.1 OS : win10 -
– Image displaying in the grafana page, Image is stored in local pc -
– using text panel-html addingtag
What happened?
– Image not displaying -
– load the image/image visibility in page -
–this is the code written in text panel , the image is stored in C drive
can you put these images in the
/public/img folder under grafana?
Then you get something like this
