Hello community,
I’m not able to display a local image into the text panel: I’m using Grafana 11 for Windows.
Could you please help me to understand how to modify the ini file if needed and how to write the path for a local file?
Thanks in advance
Hello community,
Thanks in advance
the image has to be in the grafana folder and disable_sanitize_html needs to be set
Thanks for your answer @yosiasz!
I already set “disable_sanitize_html = true” in the config file.
Just a question, which is the related windows folder for “/public/img/” in the Grafana folder?
Tanks in advance!
Thanks @yosiasz !!! it works!
