I need help on a time series
I have a time series that is already done, but the X-Axis is defined to pick the first date of the database instead the first date of the query that i defined.
I want to show the data from february and its shows, but on the graphic shows the x axis from 22 of january and i just want to show the day 1 and the 31 day
welcome @bastinhos48
what is your datasource and what does the query look like
As you can see the query is defining to the month of february but the Axis is puting this values idk why
<notifications@grafana.discoursemail.com> escreveu em seg., 10/03/2025 às 18:15 :
Its from a view of database
the result of the query its the correct you Know But show that graph
Josiah Solomon via Grafana Labs Community Forums <notifications@grafana.discoursemail.com> escreveu em seg., 10/03/2025 às 18:32 :
And this problem happens to in other 4 time séries that i have
Pedro Bastos <bastinhos48@gmail.com> escreveu em seg., 10/03/2025 às 18:35 :
They are 2 variavles that i create on that Dashboard to return year and month they are datetime
please post a fake table schema with sample mock data
